Just got dyno #s for my Gen I
Alley
Lincoln, NE
I was hoping for at least 410 with my mods but didn't quit get it. Seems a bit low to me I dunno. I got belanger headers, no cats, roe racing mufflers, smooth tubes, K&N Filters, and gears. Seems like Gen I guys with the same mods but no headers are pulling better numbers.
Put down 400rwhp 468rwtq
Thoughts?
plumcrazy
ALL OVER
not low at all for a gen 1, ive personally seen stock gen1's put down 365rwhp - 375rwhp
how many miles ?
filters clean ? new plug and wires ?
whitebluevipe
danville, pa
Thoughts?
i didn't think the numbers were too bad.
99 R/T 10
Enterprise, AL USA
That's pretty good numbers, but if you have older wires and plugs, you may be out 5-10 HP. Get a set of AB's wires and only use the stock Champ plugs.
You could also install the Tornado to get that extra 15 HP................................................ :D
A
Alley
Lincoln, NE
47k Miles. Wires were replaced at 37k miles. I just changed the plugs a month ago.
When I first got it, it had different mufflers, no cats, and stock headers of course. It then dyno'd 378/447. Will the 3.73 gears rob any HP?
SNKEBIT
western wisc.
YUP!!!!!:2tu:
99 R/T 10
Enterprise, AL USA
Def. change the wires, and I have heard you could loose 2% with the higher gears. Other say it doesn't matter.
My first car was a 96 RT(Gen I) and with similar mods as you, I dynoed at 392/472. It also had 3.73's. My best time in the 1/4 was an 11.8 at 118 MPH.
A
Alley
Lincoln, NE
Well and whats wierd too is that a couple months ago with the same mods I was on a mustang dyno and put down 362/448. I was told a mustang dyno could be 10% or more below a dynojet. And when I compare my mustang #s with other Vipers on mustang dynos I'm even putting down better #s then some Gen IIs. But its not trasnlating to the dynojet like I thought. #s don't really matter much to me, I'm just curious. I wonder if all dynos with different software and how there setup are just gonna dyno differently.
I remember one post in my search on this forum and my mustang #s were higher then his mustang #s, but my dynojet #s were lower then his dynojet #s, lol.
jasontiff
Austin
With K&Ns, no cats, high flow mufflers, Champions and MSD wires, I put down 389. Once I added the VEC and a moderate tune, I picked up another 15.
I'm heading in tomorrow to tune it with heads/cam and some other stuff and hoping for high 400s. We'll see.
sniper1
BOSQUE FARMS, NM
Those are great #s and I've heard that all the gears do is move the HP around the RPM range and maybe a little loss due to the steeper gears. Your right in there with the # cuz my 96' GTS's #s are 461rwhp and 513rwtq with pretty much the same mods except for the gears N/A no spray. :2tu:
RedEnuf93
Lancaster, PA
Good numbers for a Gen 1, most of them are under 400.
Mine was 410HP/478TQ, with stock (1998) exhaust manifolds (not the cast iron 1993 ones), 3" exhaust, no cats, smooth tubes. Close to yours. No gears......
Tom F&L GoR
Wappingers Falls
I was same as this, but kept hi flow cats and had 1.7 rockers and did 408/480.
TexasPettey
Austin, Texas
Thoughts?
Perhaps a bit low, but not more than 10RWHP low. Since dyno's varry a bit, it's probably in the range.
My Gen1 with K&N and smooth tubes dyno'd at 375RWHP.
SKY1960
