K&N filter question..
AAKVIPER
Princeton area ..Central NJ
Back in 1999 I added smooth intake hoses and K&N filters..The question is, on a 9 K mile car should I clean or replace the K&N filters? Would the dust from just sitting all these years settle on then even with the hood down and affect air flow? The car is garage kept.
I have never cleaned the air filters since new. The Viper is an 1994 RT 10..
Also any other better air filters for the job?
Thanks Arthur
hiss highness
???? not sure why u would replace k&n filters since they have a million mile warranty, they are very easy to clean, would be good to check them in case any of the sticky oil has migrated down, but since u have to open the air box to look anyway then u may as well just clean them and re-oil, just be careful not to over oil them as that goop can get sucked into the intake, if ur car has just been sitting for a few years then the filters are probably the least of ur problems(rubber,seals,exhaust,tires,etc)
Indy
Vancouver
Can't imagine dust getting into the filters in a garage. There is a K&N Filter Kit you can buy for cleaning and relubing, but I really doubt you need to.
VIPER GTSR 91
Spring, Texas
The filters will last forever but a good cleaning might be in order. KN has a spray cleaner after you remove the filters of course. Simply spray on, rinse well with a hose, then let dry. Apply the KN oil VERY lightly just to cover the filter area on the outside only. I prefer the spray oil over the bottle type for easy and light coverage. The cleaner and oil sells as a kit too. Filters do not get dirty with car just sitting there.
rlamorte
