KW suspension settings - track
Richie7
Long Island, NY
Hi,
I have KW Variant 2 coilovers in a 2008 Viper. What shock stiffness settings are you guys using for the track?
Thanks!
Rich
bluesrt
depends how fast u drive and what track- start in the middle and go from there, or find the stock settings on the acr(happy meadium)
steve911
Cottage Grove, Wi.
Somewhere in the ****** of the forums, someone downloaded the ACR owners manual supplement. It has lots of good info on shock settings as well as ride heights for the KW's
Steve A.
redtanrt10
Dana Point CA
Richie, I think the 2's have 12 settings, start with slightly more than half way, say 7 or 8. (Record the settings and adjust from there). Watch your ride height, particulary in the rear. You need to have close to 3 fingers from tire to fender lip. The rear spring rate is about 650-680 and if you're ride height is too low in the rear you'll tear up the inner fenders. I had them for a few years on my 06 and 08, as you get faster you'll want to upgrade (stiffer) the springs, 500/800 work well on them. Longer term find a set of Moton's. good luck and have fun. Mike
Axial32
