Phoenix SRT
- Joined
- Apr 17, 2003
- Posts
- 235
- Reaction score
- 0
While at the Barrett-Jackson auction in Scottsdale, I came across one of the vendors selling the Liqui vehicle tilter. The tilter is a fairly compact device that attaches to the wheel hubs (wheels are removed first). Then you can rotate the car on its side up to 90 degrees in order to easily access the underside of the car.
The device seems pretty slick and costs only $1200, although there doesn't seem to be any difficult engineering that goes into it. And the materials it's made of probably don't cost more than a hundred bucks or so. Maybe not even that. Nonetheless, it appears sturdy and looks like it would hold a car securely and safely tilted up to 90 degrees.
The device would sure make it easy to work on the underside of the car and to clean the underside. In some respects, it would be better than a lift because the stuff you are working on is right in front of you, not overhead.
Is anyone familiar with the device? If so, you're comments are appreciated. Also, I'm wondering if rolling a Viper (or any other car, for that matter) up on its side presents other problems such as spilling fluids all over. Things like the battery, master cylinder, cooling system, power steering pump, windshield washer, and oil all come to mind. Side curtain airbag rollover sensors and roll bar deployment systems also come to mind (I know - not relevant to Vipers), although my guess is that the ignition would need to be on for the side curtain/roll over protection to come into play. If some of you mechanical whizzes out there have any ideas on that, please pass 'em on.
