List of Parts for Clutch Install
Badazzv8
Jacksonville, FL
Okay, so I am going to replace the clutch with a stock unit. I've searched around and not seen a comprehensive list of parts needed. Is there anyone that has an install guide and parts list?
I think I have everything covered, but just checking.
- Clutch/PP - New LUK setup, and I've heard about the alignment tool woes, so I'll pay attention to that.
- FW - inspect, and if okay scuff up with steel wool. If not, replace with Fidanza
- FW bolts - I'm assuming these should be replaced if the FW is replaced
-PP bolts - do these need to be replaced?
-Locktite for rotating assembly bolts
-Clutch fluid - I've seen Motul RBF600 thrown out there. But the car won't be tracked, and the stock reservoir states dot3, so what are people's thoughts?
MGW Shifter - since I'll have the tranny down
TOB & Slave
Are there ANY other little things that I'm missing?
xeng yang
