Local NY Helmet Painting?
CitySnake
Manhattan, USA
I'd like to have some numbers painted on my helmet. I'd consider some "design" too, but no doubt that would increase the price. Does anyone know/use someone local that can to some simple numbers without some expensive minimum that costs as much as the helmet?
I tried with some vinyl numbers, but I couldn't manage with a curved surface and they looked awful.
plumcrazy
ALL OVER
maybe a vinyl decal/sign guy can do vinyl for ya. gonna be a minimum charge im sure.
then look into a sign painter. ive had things painted in the past and they were cheap.
C
CitySnake
Manhattan, USA
Did exactly that. Played with soap/hairdryer/razor blade...the works to get it right for a good 2 hours. Trashed it all!
I guess I'll look around for that. Was hoping someone knew someone? :dunno:
Leslie
Indiana
a guy in my car club painted my helmet for me and put my name, #, car, etc and some flames. I don't have the helmet anymore (it was SA2000), but he said he just spray painted it:) he did put the # on the back where it was more FLAT (lower center)...he said he just used a stencil.
just a thought.
now you got me thinking, I have a 2nd black helmet I might try some stuff on, would love to have a sneaky pete on it.
C
CitySnake
Manhattan, USA
I had this done by a guy in Canada.
That's SWEET...but falls into the "costs more than the helmet" catagory.
The stencil idea might work. The less talent needed...the better I do for sure!
Russ...I never left. I just lurk more now. How could I possibly give up hanging with buds like you?!
ukviper
Norwalk, Ct
I can probably do it for you. Pretty busy with baseball catchers masks and hockey masks..but I could squeeze a helmet in if its a simple design.
Nick
C
CitySnake
Manhattan, USA
Nick
Simple as a 2 digit number on the back? 4"-5" tall. Maybe in silver.
That would be great!
AviP
New Canaan, CT
It's a simple DIY job if you don't want anything fancy. Go to Autozone or PepBoys and get the following.
1. Automotive masking tape, thinnest width
2. Automotive sandpaper.
3. Primer in spray can.
4. Paint (whatever color you want) in spray can.
Everything should cost about $20-30. Then just mask the number you want, sand the exposed area, prime and paint. The hardest part will be getting the masking done right for curved numbers but a scissors will come in very handy.
Good luck!
Leslie
Indiana
Good luck!
or.. spray the entire helmet the color you want the numbers....put the numbers on, then spray helmet again with color you want the helmet to be.
rlamorte
