Locktite on header bolts?
02ViperTodd
Lawrenceville, GA
I blew a gasket today and need to replace one of the exhaust gaskets (luckily driver's side). I've removed several of the bolts and it looks like I used Loctite red on them last time. When I went to my drawer of chemicals, I seem to have red, blue, and an anti-seize stick. Which one should I use? Thanks, Todd..ps something's wrong with my enter key, another thing to fix.
I use Anti-Seize in heat / rust related (exhaust falls in both) situations.
Jack B
NE Ohio
If you are worried about the bolts loosening, use the Stage 8 bolt kit, they have ant--loosen locks on them. They look much better also.
xeng yang
