Loose harmonic damper bolt!
slither
Hey all, just for your info - I started installing a Paxton kit on my car this weekend (it's an '04 white mamba) and got to removing the stock crank pulley. I am putting on a new ATI damper so I proceeded to get out the breaker bar and socket to remove the bolt holding the damper onto the crank snout (this bolt should be torqued to 130 ft-lb.) and guess what - the stock bolt was not even finger tight! It actually had loosened about 2 or 3 threads from being finger tightened onto the damper, I was really kinda shocked. I read a post on here a while back about someone whose damper had removed itself from the crank while he was driving it and damaged the engine (I'll bet prettly badly!) glad I decided to put this kit on or the same probably would have happened to me. Anways, thought you all might like to know so you can check into it....
VIPER D
dutchess county, ny
thats what happened on my silver srt. Guess what a week later the crank was dammaged and the car was a factory repurchase. Stop and have the car checked out b/f the blower install. This way thay can blame you or the blower for it just in case.
good luck
vd..
Viper X
Yep, mine was loose too and eventually fell out. Didn't loose anything but did have to get towed in. Belts wouldn't turn water pump, alternator, etc. This car has had quite a few loose or improperly torqued bolts.
Andyk753
