low fuel light
cobrapilot
Olympia WA
Is there an adjustment for the low fuel light? I think mine is off. When my light comes on, I still have 4 gallons in the tank. And it comes on often with the new Paxton installed!
MikeR
I think most cars are set up to were you should be able to get about 50 miles when light comes on. I thought it was some federal thing just like the size of the tank matters so that cars can get a certain distance before re-fueling. For some cars that means 2 gallons, others like our car mean you need about 4, before empty.
Viper X
Hey Cobra,
I wouldn't run it down that low with a Paxton. You may have some fuel issues under heavy throttle with a low fuel level.
I don't let mine go much below 1/2 but it's modded a bunch. If you lean it out, you can detonate and cause some pretty expensive repairs.
Just my .02 cents.
Dan :headbang:
C
cobrapilot
Olympia WA
Dan:
I don't run it hard when it gets low but I also don't want a full tank and the extra weight if I'm going to "get it on". When I get near a quarter tank, I am hunting for a gas station very easily and sometimes the light comes on before I get there. It seems as if the last half of the tank goes faster.
Racer Robbie
Guilford, CT-USA
Per the owners manual you have 4 gallons of fuel left when the light stays on steady. The last half does seem to go down faster on my 2003 also but I tested the 4 gallon light and it is right on.
TRAMP 13
Montgomery ,Al
I am kind of like Viper X,I never worried about the low fuel light because I too never let the gauge get below a half so I don't know if my works or not probably will never know .2003 srt
HARDVIPER
Temecula Ca.
I ran my tank low a couple of times, no light went on and it was well below the empty line.I think mine doesn't work?????????????
Viper X
Cobrapilot,
Glad to hear that.
I think the second "half tank" goes faster too. Many times I've filled up at just below the 1/2 tank mark and I've put 11 or 12 gallons in, so our gages may not be too terribly accurate.
Dan
Mpcc
