Lower ball joint replacement boot?
Martin2000GTS
Peabody MA
Can we replace just the boot? Or am I gonna have to buy a new ball joint. Or worse from doing a search it looks like they come with an A Arm.....ehh. Can anyone chime in on this? I just needed to replace my knuckle but broke the lower boot trying to take it off. What would you guys reccomend that I replace. Whole ball joint? Or just the boot? Also any reccomendations where I can get one fast?
From reading this past post, it seems like there might be part numbers for just the boot.
I have a 2000 GTS.
Martin
M
Martin2000GTS
Peabody MA
http://forums.viperclub.org/threads...-Lower-Ball-Joints?highlight=lower+ball+joint
thats the link i meant to add to the OP. It lists the part # as the following:
lower ball joint is PN 4848174
lower ball joint boot is 52006404
upper ball joint is "the common ball joint from a full size van" (It has the squared off top to use a large socket)
upper ball joint boot is 52006405
Actually Tom, if you can chime in, this would be pretty convienient, as I need another rear caliper as well!
Tom I sent you an email from your website as well.
Martin
