M&M Headers Quality Report
Just wanted to send a shout out to M&M for the quality of their headers. Bought a used set a while back and just installed them over the Christmas break from work. These things are awesome quality, even used. Super thick flanges that are dead nuts flat so they don't even require any gaskets at the joints. Fired it up after I had the first side on to check for leaks and there wasn't a puff at any joint. Nick thick tubes as well that should put up with some good abuse. Looking forward to dyno day next year to see if I can just squeek over 500 wheel horsepower. Currently make 480 with my intake, cat-back, and tune on stock manifolds.
PaulP
awesome what was the process for re and re of the headers any tips you can offer me as i will be doing the same next week
It was really all pretty straightforward. I looked at the how-to section here as I remembered there was a writeup of someone installing the same headers on a gen 3 with some pictures. I didn't have a lift, but just jacked up one side of the car at a time and put it on ramps (couldn't drive it on as the ramps weren't shallow enough, but could slide them under after the car was up).
An extra hand helps to pull the old cats and muffler off as it's a pretty heavy assembly all together, but it's doable solo without too much fuss. I'd just advise to remove the band clamp on the factory manifold to the cat before removing the exhaust hanger bolts. Easier to break that band loose without the extra weight on it from sagging parts.
I took the advice of the how-to and removed the valve covers for extra clearance. Found out pretty much all my lower valve cover bolts were loose as well, so may have done myself a favor there anyway.
I did have to jack up my engine on the passenger side as I just couldn't quite sneak the factory manifold between the rail and the engine, but it wasn't too big a deal. Just loosened the one big nut on the motor mount and put a little pressure on the oil pan with a jack and a block. I also jacked it up to get the front section of the passenger side header in as I was having similar clearance issues, but realized after the fact that if I would have left the rear two pipe section completely loose (not even bolted to the engine at all), I probably would have had more than enough room. I only loosely bolted it on because my factory gaskets were coming apart (multi layer stainless that are spot welded together, but spot welds had let go over time and layers were separating). A new set of gaskets would have fixed this, but I did it over the Christmas holiday and needed it back together by Monday to drive to work, so didn't have time to get new gaskets from a dealer.
Sybil TF
I bought mine used for my gen 2 and they are great. Customer service is great , they will help with questions even tho they were bought used. I wouldn't buy any other brand, period.
Vipes
I've got a set and I'm also really happy with the quality. Mitch at M&M was great to deal with. Although I still haven't gotten around to installing them on the car after a year, I still enjoy looking at them in the box. lol
