Maintenance additives?
Kiaser
What, if any, are you guys using for additives on a regular basis for injector cleaning, intake cleaner, fuel system treatment, oil system treatment, etc.
Jerry Colpitts
Plymouth N.H. USA
EXP4 Gas/Petrol N&I Complete intake and combustion chamber deposit clean up. additionaly it will also lubricate piston skirts, piston rings and cylinder walls. EXP4 Oil Ehancer. Eliminate engine start-up wear by significantly reducing friction, by using the most effective antiwear agents available to smooth the effects of friction on both boundary and hydrodynamic lubrication conditions. To funtion in high-pressure applications,EXP4 Oil Enhancer also contains active and passive extreme pressure agents. :2tu: EXP4 ROCKS !!!!!!!!!!!!!!!!!!!!!!!!!!
ctrengine
