Michelin Pilot Sport Non RunFlat?
SnakeEye
Austin, TX
Anyone running Michelin Pilot Sport Non RunFlats for street???
How do you like 'em overall?
Noticeable improvement over stockers?
Any related feedback would be great. Thanks.
GR8_ASP
Yes, rears only to date.
Seems like more traction, but not much. But that was going from a worn hard tire to new so there may be no real difference new to new.
Cold traction is much more, but also may be affected by the worn/aged vs new.
No clear change in ride. These also seem to have very stiff side walls. Not much weight reduction either.
Hiss
Kentucky
My new 2006 coupe came with run flats Michelin 335 30 19. Would like to get some rear non run flat tires like the PS2's but not in production yet.
I know the PS michelin comes in non run flat but would like to have a tire that sticks better. What other tires are out there in 335 30 19. I know Hoosier makes s tires like the A6 but they are almost slicks.
slither
I am running the PS2 non-run flats on CCW wheels and have to agree with zen garage. The ride is noticeably better and traction is much better than with the run flats. I weighed the fronts and rears (wheel w/tire mounted) and compared them to stock when I put on the new ones. Rears were about 4 lbs. lighter per corner and fronts were about 5 lbs. lighter per corner. Considering I went up to a 20R/19F combo I thought that was pretty good. Taking that weight off the suspension definitely helps the ride quality but the better traction is all in the tire. With the Paxton its still pretty tough to get decent traction in 1'st and 2'nd but it's much better than with the runflats.
Kai SRT10
Salt Lake City
Are you certain that they are 335/30/19?
Previous Gen III Vipers have 345 rears.
slither
Here you go zen garage, they are CCW 505A's, 20x12.5 Rear and 19x10 front. I have to say they are one of the nicest set of wheels I've purchased for a car:
Mpcc
