KenH
The new Road & Track has the most comprehensive write-up on the SRT/10 that I've seen to date. It does not have any independently measured performance numbers, but does have cutaways of the car, CAD drawings of the frame and details which were new to me such as:
The CAM is the same spec as current, but the heads have larger intake valves (2.0") and larger ports. Hopefully these heads will be compatible with the current block.
Pistons are the same, as are the connecting rods but now they are made from something called fractured C70 steel. Guess it's a good thing.
Sidepipes actually cross-over under the car with an H-pipe. The firewall is now a single magnesium casting which saves 30lbs. Largest such casting used in the auto industry. Throttle bodies are equal size again rather than the staggered design originally shown in early pictures, etc. Oh, and a nice smokey burn-out on the front cover.
Also of note in this issue are the first real pictures of the Enzo Ferrari I've seen including a cutaway showing the engine.
