Need help from someone with a service manual!
1VprTony
OH
I need help from someone that has a 97-07 service manual.
Im looking for the pin assignments for the ignition coils... by that i mean the 3 pin connector on the 4 terminal coil, and the 4 pin connector on the 6 terminal coil (which pin is B+, cyc triggers, ect) It should be under the ignition section of the service manual around the plug wire diagrams.
Any help would be appreciated very much.
Well, Tony...there is no 2007 Viper...and, I wouldn't exactly merge info on 97-02 with 03-06. It might help to know what you are attempting...noting that you have no history here, and no real info in your profile.
1VprTony
OH
Coils are the same on gen2 & gen3, reason for the year range.
I'm making a harness for a gen1's to run aftermarket coils, different connectors.
I have the gen1 pinouts for my car in my service manual, just need someone with a gen2 or 3 service manuals.
2006
ignition coil pack-left - black 4 way
cav circuit function
1 k19 18dg/db ignition coil no. 1 driver
2 k342 16br/wt automatic shut down relay output
3 k32 18db/wt ignition coil no. 4 driver
4 k134 18db/yl ignition coil no. 5 driver
ignition coil pack-right - black 3 way
1 k17 18db/tn ignition coil no. 2 driver
2 k342 16br/wt automatic shut down relay output​
3 k18 18db/or ignition coil no. 3 driver
1VprTony
OH
Perfect!
Thank you Steve, exactly what i was looking for!
1VprTony
OH
Good luck with your project !!
Thank you, I may do a thread here to help out the gen1 guys like me get a little more bolt on spark when i have it all complete.
-Also updated my profile a little bit with a link to some pictures of my build.
ctrengine
