Need help!!! Grommet that holds Mass air flow sensor! 06 Paxton Viper
ViperCobra
Hey Guys, need help how to get the grommet that holds the air intake temp sensor. I pulled out the air intake temp sensor to clean it up but when I put it back the grommet (rubber piece) got pushed in and now it's inside. I don't know how to remove the metal piece (Paxton) that connects to the throttle. I'm afraid that the rubber grommet rolled and sunk underneath the oils reservoir (not sure of the name). How do I remove the metal piece from the throttle body to hopefully get the rubber grommet? :( Your advice is greatly appreciated :(.
V
ViperCobra
.... Here's the pic of the hole where the grommet and mass air flow sensor should be :(
Dan Cragin
LA, CA
This is the intake air temp sensor. Download the Paxton Parts list online, it has all the parts.
V
ViperCobra
Oh ok. Thank you Dan but my big problem is the rubber grommet that holds the intake air temp is inside that hole :(. How can I get that grommet inside?
PaulP
Take the intercooler off, take the pc in pic off 15min job, the grommet probably rolled into the intercooler and will be sitting on top when you look down the tube.
V
ViperCobra
Thank you for the replies! My big Thanks to AbsoluteHank (Ryan) for giving me suggestions on how to remove the elbow piece of my Paxton! It was PITA but I'm glad I got the rubber grommet back! Got this sucker back!
xeng yang
