agdetail
i am having issues with the lower bushing on the driver side. just cant seem to get enough clearance to get the old bushings out. the passenger side was no problem.
does anyone know how i would get that bushing out without removing all the ps lines? main concern is ill develop a leak since they are almost a decade old high pressure line.
cant move it enough in either directions. even tried using a big pry bar to get enough leverage. didnt work. it needs about a 2mm more for the bushing to remove.
i also have a leaking front crank seal and i have a hoist for a day to fix it.
based on what i can see, i will have to remove the nuts to the engine and tranny mount and jack the engine up to clear the pulley. other than a pulley remove, is there anything i should worry about or extra tools?
pics for reference.
thanks
pics for reference.
thanks
