need part #'s for minor work...oil leak, console lighter assembly, door panel gromet.
sssikvipe
Hope I can get some help on minor issues. I own a 2004 since new and very happy, but need to fix some things.
1. I have a small oil leak. It is coming from the passenger side and appears to be where the oil cool lines are. While there, I might as well have them both replaced as I am also in need for an oil change. On the Dodge Parts site, it shows one at aprox $60 and the other $170....? I am missing something? I would have thought the same price.....if anyone can help with part numbers that would be appreciated.
2. My passenger door panel is loose and not connected to the door frame. There is a fastener that is round and black and has a smaller circle punched into the head of the gromet that I need.
3. My lighter assembly on the console does not stay closed...I removed it, and a plastic part fell out, obviously broken......I checked to see about a replacement and it appears to be relatively cheap fix at $45 but really cant tell if thats the right part. does any one have a part number
4. did they ever publish a service/parts/assmebly manuals for this year
thank you all and safe summer cruising
Steve M
Dayton, OH
Re: need part #'s for minor work...oil leak, console lighter assembly, door panel gro
On #1, I'd recommend you take a look at Viper Specialty's pre-made lines...the factory design is prone to leaking, so you'll be replacing a bad part with something that is just as likely to leak. The aftermarket lines aren't cheap, but they also shouldn't have to be replaced.
See this thread for more info:
http://forums.viperclub.org/threads/655068-Gen-3-and-Gen-4-Stainless-Steel-Braided-Oil-Lines
Paul Scharf
Eagle River, WI
#3. I have brand new take out cig lighters for you, these are take outs from the '10 Vipers that got upgraded dash and bezels
$15 plus shipping to you,
sssikvipe
Thank you Paul, pm sent
sssikvipe
Steve, really appreciate the link...for sure thats the way i will go. I tried the search, that post didnt come up, mind you, i typed in "oil cooler lines"
SKY1960
