SEEEEYA
Just returned from the woodward dream cruise event here in Detroit(royal oak actually) driving on the highway the motor to me started to "load up" started to back fire a little had to keep shifting between 4th and 5th so we could keep going at speed if I left it too long in one gear it started to Bog down. CEL light is on P0152 is the code, I believe it is the second o2 sensor on the passenger side(correct me if I'm wrong) now I have installed hi flos and a true side exhaust. could these changes be throwing the car off so much with out a tune or is this all from just a bad o2 sensor??? or both?? have noticed it only does it when you go when the car is cold. if I drive it warm it up, shut it off for 10 min, then drive it, it does not do it, almost like I cook the o2 sensor so it works....I don't know hopefully someone knows what the heck it is
