Need Track Alignment-Help Please!
JoeB
Danville, CA, USA
Anybody, (Familiar with the Bay Area)
out there know where I can get a alignment around the Eastbay-like Pleasanton to Walnut Creek. A Hunter Alignment rack seems to be the Rack of choice.
My tires front tires especially, are wearing out on the outside and cording and the inside are like new after 11 heat cycles.
Joe B
Have you pulled the Sport Shims? That is the first place to start and it doesn't require a complete alignment. *LOTS* of good info on this topic available through the Search function.
Bill Pemberton Woodhouse
Blair,Nebraska,USA
Youv'e got mail. Depending on how much track time you plan on doing, alignment specs can be alot different. I am also assuming you are using Michelins and not Hoosiers ?
SoCal Rebell
Mission Hills, Ca USA
Joe is running Hoosiers, you gotta see his tires the inside inch or so is brand new and the outside is worn to ****. I gave him the standard specs -1.95 front, -1.25 rear plus the toe settings, he needs to find a good local shop.
tbone96
