new dyno
85 of 200
KANSAS
Heres the dyno before and after the flash, what does everyone think. 06 paxton, stock, upgraded pump and exchanger. Still looks a little lean down low, or is that normal.
85 of 200
KANSAS
Just has a dc flash, using a sct tuner. It help but not sure if it needs more? I also forgot, I have hightech cats and corsa track II.
Nine Ball
Houston, TX
I'd say that tune looks pretty damn good as-is. Nice A/F line, and the curves are smoother. I'm not too worried about WOT below 3K rpm, that rarely happens anyways when pushing a car.
This was via mail order? From DC?
utahviper
Utah
ONe of the AF readings is too lean at 5800-6000rpm. I dont know if it was the before or after but that definitely needs to be addressed.
plumcrazy
ALL OVER
id talk to DC before anyone. they know what they're doing and they tuned it for ya.
Bobpantax
Miami
The lean reading on that run is probably from lift off of the accelerator at the end of the dyno run. Nothing to worry about if that's the case. I'd say you are right where you should be. Leave it alone. Leaner may produce a bit more power but it also increases the probability of engine failure. 700 RWHP with a stock Paxton kit on an essentially stock engine is beyond safe limits. The DC blower tune is an excellent and relatively inexpensive mod. It also includes the need to go to a slightly colder plug and the change to a different thermostat. If you are going to road course track a Paxton car, it is a required mod. If you do not have the DC blower tune and road course track the car, when the cats, if you have them, get hot, the computer floods the system with fuel in an attempt to cool the cats and performance is interrupted.
