New Gear Shift Light Units Available at www.ViperRacing.net
ViperRacing
Evansville
NEW!!! Available only through www.ViperRacing.net SURESHIFT Full Multistage Gear Shift Light Units - Complete with RPM Telltale and Digital Tachometer are now available through www.ViperRacing.net.
Benefits: Five high intensity multistage Pre-shift and Shift-up warning lights give you the advance warning you need to accurately anticipate when to shift - not possible using a single stage shift light. Flashing lights at the shift point for maximum noticeability. Shift down/low RPM light warns you that you are losing performance because you are below the power band. Configurable shift light brightness to prevent dazzle if racing at night. Unique, intelligent SmartMax RPM Telltale records true maximum RPM values by ignoring momentary "glitches." Ultra high accuracy digital RPM readout can also be used as a tachometer for engine setup. Extremely simple to set up using intuitive menus on the built-in LCD. Automatic save, and simple recall of the last 4 SmartMax RPM Telltale values. Simple 3 wire "no hassle" hook up. Non volatile memory means all settings and readings are saved even if power is removed. Suitable for all conventional and MSD ignition systems, and 2 & 4 stroke engines (for CDI or Magneto systems, we can supply an HT Lead Sensor). Simple mounting requiring no drilling, cutting or fabrication.
Get them in time for Putnam!
Good Racing!
Kevin www.ViperRacing.net
