I had the problem in my 98 GTS when I removed the cats. Every now and then the light would come on. When it was on, it did not effect my A/F ratio or power according to the dyno.
What trouble codes are you getting on the '98 and newer cars? Is it a catalyst efficiency failure code or something else (catalyst heater)?
Are you getting the codes when still running stock cats?
Let me know and I'll see if I can help find a solution.
I am getting codes of 1281 and 1494. I will not get the codes if I allow the car to warm up before driving. My theory is the O2 sensors are heated and will not function properly with a cat until fully heated. It generally only takes a minute or so.
As the car has been prepared for off-road use, the cats have been removed. I have not checked the fault codes, but will do so and report back to you asap. The car is equipped with Belanger headers and exhaust system, but no other modifications.
I disconnected the battery to clear the code(s); upon restart, the light illuminated immediately.
