kwkshift
I just purchased a b/w '97 about a month ago and I have a few questions regarding mods. I have used the search function quite a lot, but I still am curious about a few things:
1) How much power(rwhp/ tq) can the stock engine make reliably with a power adder? Either bottle or blower or a combo. thereof.
2) How much power does the removal of the cats really produce? I'm looking for someone that dyno'd the car before and after. If it's only a few hp, then I won't worry about it. But, if it's 20+ rwhp or so, then I may consider it.
3) What type of nitrous systems are people running? I was looking at a TNT wet system, but I'm afraid that the rear two cylinders may run dangerously lean. Is this a concern?
4) What plugs are people running with nitrous? Stock? Similar to stock but a colder heat range?
5) What is the typical size shot people are running? 100? 200? 250?
6) I read that the stock clutch goes away at around 600 rwhp. What is the most common upgrade of clutch and flywheel? Is SPEC any good?
7) I found that how-to for the installation of the Crower rockers. I can get a great deal on Crower stuff, so I was wondering if it was worth it? Any dyno result or drag strip results?
8) Is a valve spring change required or recommended with a higher ratio rocker?
The car already has a K&N intake set-up, a 3" B&B exhaust and a ECU remap. That's all I know of for mods. It made 451 rwhp on it's first dyno pull, then the second one showed 455+, but we shut it down at about 5100 rpm due to some detonation. (Crappy 91 gas). Without that detonation, we may have hit 460 rwhp. I thought it was only going to put down about 425-435 ish.
Thanks for the information!
