C-Note
I am installing Bellanger Headers and hi flow cats on my 05 SRT I already have Corsa exhaust. I have heard a lot of horror stories about when you relocate the down stream O2 sensor to behind the cat and under the side sill. I hear that they get to hot under there and the wires rubbing on the insulation could short out and you will end up with the check engine light when that happens.
My question is, can you relocate the sensor to the far end of the exhaust beyond the mufflers? There is a lot of room behind the second muffler and you get out of the insulated area if you are in the tail pipe.
It would be easy to run the wires down the transmission tunnel and out to this location.
I just don't know if the sensor would function well that far down stream and beyond the mufflers like that.
Anybody have any thoughts on this.
