O2 sensor wire reroute for belangers
Joel
Ireland
I'm ready to fit my Belanger headers and need to reroute the drivers sensor. Where is the adjustment for the serpentine belt and what way do I reroute the wire around the air con pump. Are there any pics anywhere? I'm working without a workshop manual.
ACR Joe
Newtown, PA
Simple - First remove the belt by rotating the self-adjuster CW. Then loosen all 4 bolts that secure the a/c compressor to the block. You will need to move the compressor as far away from the block as possible to allow the electrical connector for the O2 sensor to fit through the opening created by moving the a/c compressor. Pull the connector over the top of the compressor and secure it away from the header. I insulated the wire for added assurance. Good luck .......
Tombala
