GTS Bruce
NY state No sniff test but plug in to verify systems working,Headers,no cats,corsa,syms.No check engine light and no problem passing for years.UNTIL the computer or battery is disconnected.Then the cars system knows the O2 sensor heat up is not working correctly and it refuses to do the 2 evap tests even though there is no check engine light.Instead of cruising with friends this weekend.Install high flow metal substrate cats from JON B and the o2 sensors I kept in a plastic zip lock.Yep the sills are a lot hottter again.Immediately checks and passes o2 sensor warm up.Then runs the evap tests and passes those too.Too much of a hassle to switch back and forth.Car is a little quieter.Can converse inside.Tone is deeper.Car runs smoother and seems a little mor torky.Pull the cats and use syns and you won't have a problem UNTIL the battery/computer is disconnected. GTS Bruce
