7Sins
Just received the car back from the bodyshop and I am immediately having a few issues, the car was fine before going in. When driving at any gear, the tach needle will bounce around when throttle is constant (ie I should be at a constant 3000rpm but the needle will bounce up and down), when coming to a stop it rests at 0 even though the car is still running/doesn't stall. When at a stop the speedo will bounce to 20 to 40 even though I am not moving. The car isn't running that bad besides the idle being a bit lower than normal but the power is still there and there are no CELs. Any ideas? Maybe they didn't attach the negative cable properly? Thank you for your help.
