Oil Leak, Pan?
GTS1998
Hillsborough, Ca
I started noticing an oil puddle under the front of my 1998 GTS I climbed under the car and wiped off everything. I started the car and noticed oil seeping from the front oil pan bolts. I took it to a dealership with two good Viper techs. They changed the cam sensor gasket and oil pan gasket (warranty). I got the car home, and noticed another puddle of fresh oil on the floor underneath. I heard a rumor that some of the oil pans became porous over time? Any suggestions? Thanks
DEVILDOG
VCA Member North TX
VENOMVILLE, TEXAS, USA
I had 3 porous oil pans on my '98. Was coming thru the front of the pan. Was a PITA. I finally upgraded to a 2001 10 quart pan w/baffles, trap doors and an ACR filter adapter. No more problems.
G
GTS1998
Hillsborough, Ca
Thanks for the replies. The dealer called today and said that it's the crankshaft seal. It sounds like a big job? I should have it back later in the week.
klamathpro
Detroit
I wish I had a warranty for these crazy one off problems. :( I hope I don't have problems in my first year of ownership.
SKY1960
