Oil pan advice
Christiman
Need some advice from u pros. I'm puting a 04 srt10 viper motor in a 61 Chrysler. The oil pan drops Down about 10" in the back. I need to put a pan on that don't drop down. I tried a viper car pan but it's too short and narrow. Is ther a pan I can use and if so which one?
yotehunter
There are not many options for pan styles for the V10, should not be to much trouble for someone in the know to make a custom pan using one of the originals as a starting point.
Mopar Steve
Newark DE
From your post, I am guessing you are using a Ram SRT-10 engine. The corresponding year car engine will fit correctly and not drop down as far. The earlier year car pans are not interchangeable. You will also need to get the sump/pick up assembly inside the pan.
