ok so its not a viper but it has a viper engine 2
venom426
My awesome 55 being built in UK with a gen 4 Viper engine. :)
venom426
Thanks Matt thought I was getting the cold shoulder as not a Viper lol. Work been done by Wayne Streams in UK.
Cape Coral, FL
I think its cool as hell.
If you get into a bind with Engine Management, let us know. Dealing with the OE G4 harness and PCM may be more headache than its worth in that application, as it is in nearly all Resto-Mods using Gen-3 and especially Gen-4 drivetrains.
venom426
Thanks for the heads up Dan do you make a stand alone loom for this deal.
Roysviper
Milton,FL
Hey.......you have the best of both worlds....a classic 55 Chevy and the Viper motor.........seems both would be very RARE in the UK????? definitely gonna be a hugh conversation piece everywhere you drive it over there.............
venom426
Thanks Roy never did like normal !!! We also have a 55 1st gen Chevy truck which we are putting a Cadillac Northstar engine in with one of CHR Fabs from USA gear box in. Guess I was born the wrong side of the pond.
venom426
Does anyone do a different computer for this sort of application.
Cape Coral, FL
Absolutely.
Here is an example of a Viper Standalone set up for install in the Rolls Royce from the other thread:
venom426
Looks good Dan what else will I need to run the engine. The guy who I bought it off had an ecu built at a cost of $4500 but as yet I have not seen it.
Cape Coral, FL
The Gen-4 would require a slightly different path on the ECU, but would still end up being very much the same as shown above, albeit a good bit more complicated. Other than shown, you would of course need all of the chassis-side wiring to integrate, Solid State control relays, basic fuse block, fuel pump/system, and you would need to decide whether to retain the Drive-By-Wire [Needs accelerator pedal & possible ECU DBW software upgrade depending on ECU], or go Mechanical, which would not need the pedal, but run an alternate wiring harness design, and require our custom 5-axis Billet Throttles and manifold modifications to operate.
I can tell you however, at 4500 it is no surprise that the product was never delivered. That would not cover the cost of any custom standalone ECU and hardware for a Gen-4, let alone the labor to assemble it.
venom426
How much do you think I am looking at Dan if you supplied all I need. I have the pedal assemble for the drive by wire which is fiited in the car.
Cape Coral, FL
Please E-Mail me [[email protected]] with as many specifics as possible as to what systems will be in the car that are engine related, what may be attached, rough ECU location, where you would prefer the harness meets the engine, other details, etc and I will put an estimate together.
Also, include the intended gauge layout. You will likely need tee'd in secondary sensors for mechanical gauges, or we can source some gauges that will work with the ECU and sensor type already being used -some may not be available however- or easiest yet, if a "tech" solution is doable, we can offer configurable digital displays that can be integrated in the dash, eliminating the need for any gauges in the car. These displays can mimic analog gauges if so desired.
Torquemonster06
Kiezer Oregon
I know some of the chevy and mopar diehards will throw a hissy fit. But this is going to be Bad A$$. Deff keep all of us posted on this project.:2tu:
venom426
BLK04 you are right especially if the air bags get a leak at the same time lol. Thanks for all the comments I will post a few more pics this week.
venom426
A few more pics before and after body mounted.
venom426
And the after.
VenomXX
