santo
This is kinda hard to explain when you don't know what the pieces are properly called so here goes...
My passenger window rolls down too far. The glass hits a stop on the guide opposite the hinge side when being rolled down and the "female" plastic piece that pulls the window down on the middle rail goes farther down until it hits the bottom of the rail. This, in turn, causes the window to stop where it should but the little "male" piece attached to the glass pops out and the "female" piece keeps going lower. The window will roll up but the little "male" piece attached to the glass pops back in when the glass is fully closed only (with some momentum). If I don't the close the window fully, the glass will not slide down because the "male" and "female" piece aren't attached.
Can I stop the "female" piece attached to the middle rail from going down too far?
Hope that wasn't too confusing. I should have taken pictures when I had the door apart.
Thanks,
Santo
Thanks,
Santo
