Passenger Window Started Squealing
am.mscl
Austin, TX
This is on a 2001 GTS ACR if it matters.
Yesterday we were putting the passenger window down and about the 1/2 way mark a squealing noise started.
Go to put the window up and the squeal is heard until the 1/2 way mark and it stops.
We were able to repeat the process 3 or 4 more times.
Is something getting ready to stop working?
Or do we just need to put some grease on the window track?
Ray
CEJ
Raleigh, NC
I'd say something about lube, but I think Dave would have a field day with that too...
Fatboy 18
Surrey, United Kingdom
Plan A Take off the inner door, clean the track that the shuttle that slides up and down on. Use some silicone based lubricant or white lithium grease. also put a bit of fresh lube on the cables. With the door panel off try running the window up and down and you may get a better idea of where exactly the squeak is coming from :)
Plan B Turn the stereo up when using window switch :D
bluesrt
plan c- stop useing the window- plan d--- pull the glass and trac the car---plan e.... sell the car
A
am.mscl
Austin, TX
I went ahead and greased the tracks and put the panel back on. No more squeal at this time.
jpolen21
