Pics of 20" wheels with eibach's/spring caps?
Shank2117
I may be asking for too much with this request, but by anychance does anyone have pics of 20" or 20/19" wheel setup with the eibach's or eibach/spring caps?.
Everyone that I know that has this setup has an adjustable setup to give it that really low look, I just came up on a set of 20/19" wheels but im thinking it may sit really high with the eibachs?
FLATOUT
Modular Concept Carbon 03's in 19/20 with Eibachs, and caps in the rear only. Only Springs up front.
Hope this helps.
Andy:2tu:
Nine Ball
Houston, TX
19" fronts, 20" rears, Eibach springs, factory caps. If I were to do it over again, I'd also put the lowering caps just in the rear. The front is low enough without them, in my opinion.
YellowViperSRT10
Florida
Those wheels look great, what are they?
BOMBOVIPER93
Berlin, Connecticut
20" iForged front and back with eibach spings and lowering caps.....rides mint! who needs 4k motons !:D
Dom426h
DE
Tiago's viper looks too low to me. Id just go with the eibach springs to keep some decent travel in the suspension.
But hey, Why does Tiago look lower in the rear than BOMBOVIPER93 when they both have the same springs/caps/wheels:dunno:
Tiago
Houston, TX
I dunnno but my car does sit lower then other cars with same setup, I can't explain it... other than its just old and sagging :rolaugh:
I like it low though :D
witz323
Delafield, WI
that black SRT-10 is one of the best looking i've ever seen. I'm definitely doing the caps and springs next year, hopefully wheels too.
viper04
I know this is a old post but, any more input on the "eibach spings and lowering caps". Thanks
2easy
Calgary AB
I just did mine with springs and caps on the stock 18s and 19s. I love it! It rides great and no rubbing. I will say that once you lower it you will notice that the wheels need to be kicked out a bit, either with wider tires or spacers. It just doesn't look right. Instead of buying larger tires and rims I went with spacers to get the same look. Once you lower your car, you will wonder why you hadn't done it sooner. I cant see spending absurd amounts of cash on a suspension system, unless you are racing. I would post pics but I cant figure out this stupid thing to do it....Im computer illiterate as you can tell. lol. Good luck
dester243
How does it ride after being lowered on the eibach springs? Stiffer?
2easy
Calgary AB
2easy, how wide of a spacer you need if running stock wheels?? Thanks
3/4 in the rear and 3/8s on the fronts. Runs fine with the stock 10 spokes. No issues with rubbing. Great set up for the money IMO
viperkim
