Pictures or instructions on removal of the sub box,,
8mywal8
Pictures or instructions on removal of the sub box in a 06 coupe. Ant help would save me some time.
08viperviolet
coral gables FL
You need to remove the seats then you will need to remove side plastic around the rear panel. Then go and open the trunk and remove the push pins. Then remove the cover up panels from the trunk that attach above the seat-belt. Then you have to remove mounting bolts on the panel. Remove panel from the car. Then there are 4 bolts hold in sub box.
Hope that helps.
Joshua
