Re: PNP AEM Harness\' - where are they?
Check engine light solution
1. remove the gauge cluster, not that hard at all, then pull the check engine light bulb = no more engine light
1.1 even cooler, then run a wire from the AEM LS#10 (AEM’s check engine light output) to the light bulb and solder = now you have a working AEM check engine light and you can program it to alert on just about anything you want.
