Possible IAC problem
1HOTV10
Thousand Oaks, CA
Having problems with my 2004 Viper not idling correctly when at a stop (stalling). It has been brought to my attention that the problem could be a stuck Idle Air Control Motor. If so can it be serviced or just replaced.?
I have used the search engine but no luck any input?
1HOTV10
Thousand Oaks, CA
Just found a post 11-08-2005 RT/10 GTS Discussions. The Wizard says to clean the control motor with starter fluid. Yes?
swexlin
West Chester, PA
How old is your battery? Last winter I had an issue with not wanting to idle at cold start, and a new battery fixed it.
1HOTV10
Thousand Oaks, CA
The battery is fresh. Starter fluid is what the thread spoke of. I agree the carb spray cleaner
would be better.
