Problem starting??
wow
Baltimore, MD
Just tried to start the car, 96 GTS, and the engine will not turn over. I don't want to keep grinding the starter. Viper has been sitting for 3 weeks. Battery seems to be ok. Any suggestions?
Snake Bitten
Southern Kalifornia
It's your battery...try throwing a trickle charge on it for a couple of days (Battery Tender)...and then keep it plugged in whenever you know your car is going to sit for an extended period of time...
You can install the Battery Tender up front on the drivers side...no need to get into the battery compartment...
ctrengine
