problems with fuel pump
RENTME
I ran my 97 gts out of gas, now with fresh gas and fuel filter car will not start anybody else heard of problems like this and or a resolution ..:dunno:
Thanks tom h
rentme:dunno:
99 R/T 10
Enterprise, AL USA
You might want to cycle the fuel pump about 5-10 times(turn the key to the on position then off) until you hear the sound changes (lower whine).
NEVER LET YOUR CAR RUN OUT OF GAS!!!!!
:D :D :D
2000_Black_RT10
Up North
There should be a schrader valve on the intake manifold (also on a 97?), try letting some air out to prime the system or to check if there's pressurized fuel in the system when the key is on?
I've ran out of gas.. but it started up ok.
Tom F&L GoR
Wappingers Falls
If you continue to have problems, you can force the pump to run 100% of the time (when key is on) by connecting K31 20 BR/VT (brown/violet stripe) wire in the plug harness (next to the amplifier in the trunk) to ground. The PCU switches the pump on by grounding this lead.
R
RENTME
NEVER LET YOUR CAR RUN OUT OF GAS!!!!! no shi. huh
:D :D :D
I tride this it still just will not start thanx !!!!!!!!!!!!
R
RENTME
:drive: I have a roe blower is that valve changed over to the roe intake ????
R
RENTME
Is it possible that the pump could have burned out or gotten damaged buy cranking it with no gas in the tank ?????? Thanx:confused:
R
RENTME
thanks for all your help guys the viper is back up and running !!!!!!!!!!!!:drive:
