What Gen car? I just did a shift beeper install write up (may have migrated to the PAY section) on my GTS and I picked up the tach wire in the driver side footwell.
The Gen 1 you can get at it from the back of the tach.
In both cases you can also tap the wire at the PCM under the hood.
Well, for whatever reason we can't find the gray wire with the blue tracer. What connector by the PCM under the hood would it be in? C3, the front one?
To find the wire at the PCM: It is located in the Gray PCM connector (C101), Pin number C31.
The connectors can be removed by squeezing tabs on the top and bottom. The pin numbers can be seen on the inside of the connectors if you so desire. However removing only the back cover of the connector is all that is required. This should pry off easily without removing the connector or damaging the cover.
Well I got it all installed and it doesn't work. Got 12V and ground so I have no idea whats wrong. I know I have to set it higher than intended to work with the V10, but even setting it at 3K it doesn't come one. Ideas?
I set it for 4 cylinder mode like some do with the Auto meter and it seems to work, once the snow clears I'll give it a shot on the street with some real RPM.
It takes a tach signal, and it works now. Had to set it for 4 cyl. mode and it operates at 80% of the RPM setpoint. I set it to 6700 for about 5300 turn on.
