Carl 2002 GTS
I noticed the passenger side door sill is bubbling right below the sticker that warns you about the heat. I'm starting to think this probably shouldn't be happening. Seems like the insulation is missing or thin at that spot. Should I expect Dodge to correct it under warranty? Also, I get this funny clunking sound when I back out of my driveway or pull slowly over uneven pavement. Seems like its coming from inside the **** where the tranny and driveshaft are. The dealership's mechanic called it "tin canning". He said the chassis and frame flex at that point and that probably some sheet metal that covers the hunmp is popping in and out. He said its nothing to worry about. Anyone else heard of this in a GTS?
