Question on best 17'' drag radial
Nates GTS Viper
looking for drag radials for a set of ccw rims i have that i want to be able to drive to and from my local track. i was wondering if the m&h 390/40/17 will fit on a 96 Gts with kw coilovers. the specs are 14.30'' section width, 12.50'' tread width and 29.50'' tall. i know that it is a bit big but would it work with the coilovers is my only question. thanks in advance
Madduc
Fremont,MI
I use the Hoosier DOT Drag radial in 335/35-17. I think the one you picked is too tall, but others may prove me wrong.
1TONY1
Dalton Ga. (Chatt. Tn.)
Based on my experience with 28" tall ET streets you will have to do work to get them on due to the height. I also have the Hoosier drag radial. It is the same tread width as the M&H but I don't think it is street legal if that matters to you. Doesn't have a treaded look either. MT has a 315/17 with tread.
sdaddy
Jacksonville, FL
I ran the 17" Hoosiers and liked them, but with the 3.07 rear, I could not get above 120 without hitting the rev limiter in 3rd gear. They are not all that tall. I switched to 18" wheels to go to the taller MT ET Streets and pick up about 7 MPH in 3rd. They are 28.49 inches tall and barely clear the wheel wells on a stock ride height. I have not been to the strip with them yet. I felt a lot more comfortable doing street driving on the MT ET Streets as they have a tread pattern unlike the Hoosiers that only had two grooves. They are 345's which are a little wider than the Hoosier 335's also.
viper k
i use hoosier drag radial 335/35.17 i think they hook up better than any street radial out there 1996 gts 11/60@122mph
1TONY1
120 mph ?? That problem is easy to solve. Boost and forth gear !!! :D
Mpcc
