Question on wheels.
smcosta90
Central NH
I apologize but these are some nub questions I had.
I have the eibach lowering springs on my gen II. I wanted to know if anyone is running 19s or 20s with the lowering springs on their car? Could I go to 20s with the lowering springs? Has anyone tried?
What is the effect of increasing wheel size?
I always assumed it would increase the overall height of the car by 1/2 of the increase in size i.e. if you go from 18 to 19 the car would ride 1/2" higher.
Do I need to do any recalibrating of the speedo or a wheel alignment?
RobZilla
Jacksonville, FL USA
Did you install the Eibach springs, or did you take it somewhere to get done. I am taking on this task in the next week or two and want to know how tough of a job it is, and if there is anything I really need to consider when doing it.
:usa:
MTGTS
Orlando, Fl
:usa:
It's not bad. I did it in my garage. The biggest PITA is lining up the rear bolts when putting the spring/shock back in. I took mine down the street to the local tire place to have the springs swapped out on their compressor. They chraged me $10 each and I did all the rest.
smcosta90
Central NH
As long as you retain the original rolling diameter of the OEM rim/tire combo you should not need to recalibrate your speedo. This is the so-called "plus-sizing" concept:
Tire Tech Information - Speedometer Accuracy
Tire Tech Information - The Plus Concept
Hope this helps.
/Rich
Thanks for the info. That helps on most of my questions.
One of the big concerns I have is rubbing. I don't want the tires to hit the wheel well.
Rub,
The previous owner had put the lowering springs on. Sorry I couldn't help.
