R134a AC gas capacity
carlv12
Valencia, Spain
Hello,
I need to know the capacity of the R134a AC gas in a 3rd gen. Viper SRT10 from 2004.
I know that the service manual only states "Refer to the A/C Underhood Specification Label located in the engine compartment", but my Viper has a 2008 hood and I cannot check the label on my original hood. So please make a picture of the label and tell me the capacity.
Thank you and best regards from Valencia
Carlos
AZTVR
Chandler AZ
Sorry, I can't help with a specific answer. For refrigerant capacity, the service manual only states "Refer to the A/C Underhood Specification Label located in the engine compartment" and I don't have access to an SRT10.
steve e
If you can get a set of AC gauges, You don't need to know capacity, fill from the low side on till the high side is 150psi , that should be fine, if not cold enough add a little more, keep it under 200 psi.
C
carlv12
Valencia, Spain
Hello again,
I hope you can help me, because here in Spain there are no other Viper's around to check.
Thank you
Regards from Valencia
Carlos
AZTVR
Chandler AZ
Hello again,
I don't have access to a 2004 Viper; but, I see in photos online that the label is not on the hood itself. It can be seen in the lower right corner of this photo from an eBay ad. Maybe someone can take a close up of one.
