viperbilliam
I'm thinking of getting these Random Tech cats that PartsRack sells for $600 for my stock exhaust system on my 05. Anyone go this route? How did you like it and how did the install go?
The flex pipe is NOT an issue....ask anyone of the many hundreds and hundreds of those we have installed. Flex pipes are removed w/ performance header applications in fact. FLEX PIPE itself is the bad issue! It decays inside. It is restrictive inside. It simply is not needed.
We did extensive flex research pre-1999, even into marine flex applications. Determined it was NOT needed. And we stand by that with a replacement warranty if "NOBODY"s guesswork came true in 5 years of install. But we have NEVER HAD A FAILURE!!
Before we had the SRT10 bolt-ins, we had (and still have) splice-in cats that can be fabricated in to keep the flex, and save some $$$ if you want to spend it on install time instead..... Several BIG tuners and dealers still get these from us and do it for less $ and keeping the flex.
Our RT cats are Viper Specific, and WARRANTEED 5 years....flow rates published and guaranteed. They are not Interpid or no-name cats with NO flow rates, or with serial numbers ground off.
