Rattle when in reverse and idle
supra360
Ontario, Canada
I have a 1999 RT/10, I owned it for over 2 years now. When the pass few weeks I get a bad rattle when I am in reverse and idle I never use to have it before. How do I tell if its the neutral gear rattle?
Ron
Indianapolis
If it is louder than before, not NGR. In reverse with the clutch in or while backing up?
CEJ
Raleigh, NC
Does the rattle change with speed when you're backing up? What fluid are you running in your tranny? How many miles on your Viper? Are the engine/transmission mounts original? Thanks.
CEJ
Raleigh, NC
Since it rattles in neutral, have you put the car on a lift while running to see if you can locate the rattle? (with the tires chocked)
When in Neutral, if you step on the clutch, does the noise go away or change in any way??
SKY1960
