Red Fluid?
Jim C
Edmonton, Canada
I just pulled out of the garage and noticed a pool of red fluid on the garage floor (new ACR). I'm assuming the tranny fluid is red... is that right? Crap. Time to get under there I guess. So much for the after work stress relief cruise...
adamlotus
los angeles
onmy 08 vert i had left rear shock was loose,oil pressure switch was loose sometimes you will find loose things on a hand built car
Tom F&L GoR
Wappingers Falls
I'm curious. I thought newer Vipers used the 75W-85 oil in transmissions and it is pale yellow. I also thought the power steering fluid was clear (at least it is in my '06 Charger) so you wouldn't mix it up with ATF. Or my memory is going... can't remember. Maybe Dodge went to ATF in the PS - would like to know. Thanks.
They are one and the sane...different names (and price/oz!!!) for 2 different package sizes..."Power Steering+4" is a pint while "ATF+4" is a quart!!!
Tom F&L GoR
Wappingers Falls
There was a time when PSF needed extreme pressure additives to protect the high pressure vane pump, meaning ATF+additive=PSF. Thanks for the info.
gfal0003
