Repainting the hood grille covers
Got_Vnum
Northridge, CA
Any advice on what type of paint to use or general "how-to" on repainting the black hood grille covers? They are off the car and I would like to get them looking like new again.
G
Got_Vnum
Northridge, CA
Sweet. Thanks Dave. I got a can of Rustoleum flat black. I'll exchange it for the satin. Any prep work needed? I'm thinking of giving the existing paint a light wet sanding with 2000 grit before painting. Thoughts?
G
Got_Vnum
Northridge, CA
Ha! I already lost one screw and I think theres another one in there from a previous owner. I have a couple of rare earth magnets from a dismantled computer hard drive that should work. Thanks Steve and Dave for the great tips.
Brent
Flint, MI
The factory paint was flaking on mine. I used a screwdriver with a telescopic magnet to catch the screw while I had someone hold a flashlight for me. Also removed the rubber gasket to sand and paint them.
I wet sanded with 800 grit and you could go as low as 600 or 400. If you sand with 2000 the surface will be too smooth and the paint will flake off eventually because it had nothing to bite onto. I used Krylon satin or semi-flat and did one light coat, let it tack for about 5 minutes and did a 2nd coat to cover. Putting them back in wasn't too hard, just taped the screw to a screwdriver, had help holding a flashlight and threaded the screw on about half way and pulled the screw from the tape, did all four, then snugged all the screws down.
BlackSnake99
Northern Virginia
If you decide to go the rattle can route, I would recommend baking the paint at 200* for an hour. I've done this on several metal parts and it really makes the paint durable.
PS- Open the kitchen windows unless you want to hear your wife complain about the smell. Don't ask me how I know that....
dave6666
Or as we say in Texas, park the car outside for 15 minutes :D
webironmongery
