Replacement clutch and flywheel
gb66gth
Big-D
The title says it.
I need recommendations for a replacement clutch/pressure plate as well as flywheel.
I'll stick with OE slave cylinder.
I do track the car but do not want a full race spec. , nor do I want OE spec.
Suggestions?
Nine Ball
Houston, TX
What is wrong with the OEM dual-disk? Those seem to get good reviews. I run a Bad Boyz Garage dual disk in my car, but that is because I have over 1,000 ft-lbs torque. No complaints!
treesnake
St.L
Call Toddy at Bad Boys Garage.....:2tu:
(I think I've broken just about everything in driveline except my BBG clutch/flywheel......:rolleyes:
webironmongery
