RSI Fuel system
TangeloPearl
Have a ton of pics Of parts just let me know what you need 516-591-9886
I purchased this kit to use on my 2003 Paxton supercharged Viper but never got around to upgrading and ended up selling car for my current supercharged Huracan. This system is proven and used throughout the viper community for making any sort of power NA/or forced induction.
- RSI TWIN Fuel Pump Hanger Kit with optional plug and play harnessfor Dodge Viper Gen 3 (2003-2006) - $1021.88
Deliver more fuel to your high powered Dodge Viper with RSI's Fuel Pump hanger kit! Our hanger is built from precision machined aircraft-grade aluminum with a black anodized finish for maximum durability. The hoses and wires are fuel submersible for long life.
Features include:
-RSI CNC Billet Fuel Pump Hanger
-Twin genuine Walbro fuel pumps with pre-filters
-Built-in fuel mainifold chamber for better pressure equalization and no external couplers
-Feed and return ports are AN -8 to handle larger fittings if needed (used on triple pump hangers)
-RSI "Plug and Play" Wiring Relay Harness - Optional
-Comes fully assembled!
- RSI Fuel Rail Kit for Dodge Viper Gen 3 (2003-2006) - $431.92
RSI fuel system components are designed and made to be the best fuel products in the Viper performance market! Our Gen 3 Fuel Rail kit is no exception. Our fuel rails start with our own designed extrusion that is pushed from a solid block of 6061 Aluminum. The extrusion is later CNC machined and finally buffed for final appearance. The included brackets are also CNC machined billet 6061 and are designed to securely hold our rails in place without movement from higher pressure injectors.
The RSI Fuel Rail Kit Features:
- 6 Billet 6061 Aluminum Mounting Brackets
- Stainless Mounting Hardware
- Black Anodized Finish
- Top Feed 60mm Injector Design
- AN -8 Inlet and AN -6 Outlet
Also included is the optional polished throttle bracket relocation kit
Everything is packaged and ready to go all Plug and play !!
Comes with all fittings as seen still in package brand new
All you will need is injectors and a fuel pressure regulator.
Tombala
